17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
15 years agoHi,
Thanks for all of your replies... I am simulating the system for now, using Modelsim-Altera, will be running it inside FPGA after the simulation..and I am using HDL.. The problem is solved...since I was only checking the write operation so pay less attention to the readdata and read signals and the mistake was in readdata and read signals connections :) Now I am able to successfully read and write separately...now going to combine these in one module and lets see how it goes.. thanks sawaak
