17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
15 years ago --- Quote Start --- Did you reset the TSE first? Did you check the polarity of the reset signal? --- Quote End --- Hi, Yes, I have applied the reset and the polarity is high. regards, sawaak
