17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
16 years agoHello,
I think I connected everything I should: Clocks: clk ff_rx_clk ff_tx_clk rx_clk tx_clk are all connected to the same 125 MHz clock. I provide a reset on simulation start for 100 ns, after reset goes low the mdc clock output starts so I think this is correct. Regards flint
