17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
16 years agoDo you provide all the clocks (including the Avalon streams and the MII interface)?
Did you check the polarity of the reset signal? Do you send a reset pulse at the beginning of the simulation?
