17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
17 years agoBe careful that the reset signal on the MAC is active high, not low.
Altera provides an independent test bench for the TSE mac (see chapter 5 of the documentation). Can you run it and check the differences in the signals with your test bench?
