17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
17 years ago --- Quote Start --- Is your reset or clock stuck? Jake --- Quote End --- I set right value of clock and reset.I made mdc output and found it was right.But waitrequest was always 1. Is there other proplem may cause the unnormal phenomenon? Thanks,Jake.:) P.S.:the attachment is my project,could you help me to check it?
