Can you read carefully previous posts?
BrianSune_Froum wrote:The issue is changing from HRC to SRC introduce stuck or hang on Linux driver load.
This is referring to the PCIe itself not slot card nor end-point devices.
You are not even able to type any thing as it stuck or hang once the pcie-altera.ko insert.
"Once confirming PCIe link info correctly in lspci, you can try rescan and reset commands by referencing https://unix.stackexchange.com/questions/73908/how-to-reset-cycle-power-to-a-pcie-device"
>>These are Linux commands to test your PCIe. No need to load driver.
Rong
- BrianSune_Froum1 month ago
Contributor
I am amazed how can you run lspci when root port not even exist?
Maybe another Altera staff can help this ticket?
Feels like you are not well understand the entire PCIe system.
And stop quoting useless stackexchange this is completely not related this ticket nor what it is asking.
- RongY_altera1 month ago
Contributor
I was not aware of this is a RP use case so my previous suggestions were not aligned to your needs.
I noticed you have another similar topic in the forum with better statement.
https://community.altera.com/discussions/fpga-device/avalon-mm-cyclone-v-hard-ip-for-pci-express-intel-fpga-ip---hard-reset-to-soft-r/350590
To prevent duplicate threads on the same issue, this topic will be closed. Thanks for your understanding.
Rong
