17 years agoAvalon master to SDR Sdram help please
:confused: Hi I have created an Avalon master which is connected to the SDR Sdram controller. I am not using nios but am using an external micro. Being new to this I am having a problem with u...
17 years agoI have been working on a similar problem, I am working on a VGA generator. I found a simpler SDRAM controller than the avalon one, it is part of the download for the CII starter kit, you do not need to use the SOPC builder or avalon to get it to work. It comes with the 'cyclone ii starter development kit (http://www.altera.com/products/devkits/altera/kit-cyc2-2c20n.html)' you can download the CD distribution that comes with it for free from the altera web site. I am using the starter kit and it works fine, I am sure you could use it with any board and SDRAM. The filename is 'Sdram_Controller.v"
