RobShepherd's avatar
RobShepherd
4 years ago
AVALON IP LIBRARY
Hello, I am investigating the AVALON Bus Protocol as a standard to be used in a RISC-V SoC design.
I understand AVALON to be an OPEN standard but wish to understand what AVALON IP/Macros/RTL are available for licence/purchase to support the SoC development.
Is there a simple link/URL that will show me the available IP or do I need to use a development tool to reveal the available IP library?
Thank you in advance,
Rob Shepherd
    • RobShepherd's avatar
      RobShepherd
      Sstrell,
      Thank you for this, you have saved me a number of hours searching.
      I am very grateful,
      Rob
      RobShepherd
      Hello again,
      (Sorry to ask)
      Do you know whether the IP that is described in the guide is available in HDL form or is it a drag and drop thing that is configured and pops out from the Quartus process as a binary for programming FPGA.
      The guide is named "Embedded" IP which may mean the IP is embedded in the tool only but section 41.3 (item suggests a "Generate HDL" stage but I am not sure if this applies to all items in the guide.
      Please let me know if you have experience of this.
      Thank you,
      Rob
      • EBERLAZARE_I_Intel's avatar
        EBERLAZARE_I_Intel
        Yes, you can drag and drop and edit the IP as per the guide, and after you connect everything without any warnings/errors, you can generate the HDL.
