AVALON IP LIBRARY
- 4 years ago
I don't know if this helps, but here are the Avalon specification and the Embedded Peripherals User Guide, which documents much of the IP included in Platform Designer in the Quartus Prime software for working with Avalon interfaces:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
Hello again,
(Sorry to ask)
Do you know whether the IP that is described in the guide is available in HDL form or is it a drag and drop thing that is configured and pops out from the Quartus process as a binary for programming FPGA.
The guide is named "Embedded" IP which may mean the IP is embedded in the tool only but section 41.3 (item
Please let me know if you have experience of this.
Thank you,
Rob
Yes, you can drag and drop and edit the IP as per the guide, and after you connect everything without any warnings/errors, you can generate the HDL.
