13 years agoAvalon- Wishbone Wrapper OpenCores CAN Protocoll Controller
Hi, I know that this has been discussed in some old threats but I could not get some real help from those. I want to use the CAN Protocoll Controller in my NIOSII system designed with QSYS. I t...
13 years agoI used the OC CAN controller on CIII and this is my wrapper (Verilog).
As you can see, I don't use readdatavalid signal.
module CAN_av_wrapper(
//Avalon common
input av_clk,
input av_reset,
//Avalon control port
input av_address,
input av_chipselect,
input av_write,
input av_read,
input av_writedata,
output av_readdata,
input av_byteenable,
output av_waitrequest_n,
// CAN interface
input CAN_clk,
input CAN_reset,
input CAN_rx,
output CAN_tx,
output CAN_bus_off,
output CAN_irq,
output CAN_clkout
wire wb_ack_o;
assign av_waitrequest_n = wb_ack_o;
wire wb_cs_i;
assign wb_cs_i = (av_byteenable == 4'b0001);
assign av_readdata = 24'hz;
can_top wishbone_can_inst
.wb_clk_i(av_clk),
.wb_rst_i(av_reset | CAN_reset),
.wb_dat_i(av_writedata),
.wb_dat_o(av_readdata),
.wb_cyc_i(av_write | av_read),
.wb_stb_i(av_chipselect & (av_write | av_read)),
.wb_we_i(av_write & ~av_read),
.wb_adr_i({2'b0, av_address}),
.wb_ack_o(wb_ack_o),
.clk_i(CAN_clk),
.rx_i(CAN_rx),
.tx_o(CAN_tx),
.bus_off_on(CAN_bus_off),
.irq_on(CAN_irq),
.clkout_o(CAN_clkout)
endmodule
