15 years agoAudio Extract MegaCore
Hello, we are planning to buy Audio Extract core for audio extraction from SDI signal. The datasheet says, that the output is 12S/AES. Is there a mistake and it is possible to get I2S audio output...
12 years ago --- Quote Start --- Hi, YUFU0511 and Socrates! SDI Audio Extractor has not only aud_clk_out ( which is an output ), but also aud_clk ( which is an input ). Both are described as being 3.072 MHz. How to deal with that? Where from do I have to take 3.072 MHz to feed to aud_clk input? From aud_clk_out output? Does that mean, that I have to connect aud_clk_out to aud_clk input? It seems strange, that Audio Extractor may need anything else besides input video signals. Did You try connecting aud_ws, aud_data, aud_clk_out to I2S inputs of any audio processing IC? If Yes, the does it really recognize them as I2S ? --- Quote End --- Hi, Aphraton, About the connection question, you may see an example design for audio extractor. (The example design can be found in the folder xxx/altera/(your quartus II verions)/ip/altera/audio_embed/example/) For your second question, in my case, I extract AES audio and write my own module to convert the AES audio to I2S signal.
