15 years agoAudio Extract MegaCore
Hello, we are planning to buy Audio Extract core for audio extraction from SDI signal. The datasheet says, that the output is 12S/AES. Is there a mistake and it is possible to get I2S audio output...
13 years agoSDI core and audio embed/extract cores are separate. Since SDI core will give/take BT656 on output, it means, that You can use audio embed/extract on any BT656 stream You have.
P.S. or BT1120.
