15 years agoAudio Extract MegaCore
Hello, we are planning to buy Audio Extract core for audio extraction from SDI signal. The datasheet says, that the output is 12S/AES. Is there a mistake and it is possible to get I2S audio output...
15 years agoi'm sure that must be a typo and its meant to say I2S
on the other hand that is the only reference to I2S in the documentation. on page 93 of the SDI UG, it says the SDI cores use the AES standard, so i'm not sure why the document shows I2S as well. you might file an SR to get clarification i don't think converting AES to I2S should be too tough if that's where you end up
