13 years agoaud_ws_in signal in SDI audio extractor
Hi The aud_ws_in signal in SDI audio extractor is used as a reference word select signal to align the serial outputs of multiple audio extractors. (please see SDI use guide for the original d...
12 years ago --- Quote Start --- Hi, Aphraton I eventually find the signal "aud_ws_in" can do the work for me. You may see the SDI user guide to understand how to use it. --- Quote End --- Yes, I understand how to use signal "aud_ws_in". But You reported, that You had problems - output data not being aligned as seen in Your SignalTap screenshot. How did You solve output data not being aligned?
