ArriaV thansceiver jitter tolerance
Hi, my FPGA chip is 5AGXBA3D4F31C4, i want to ask some help for transceiver jitter tolerance.
1. For Receiver PHY, PMA includes CDR module, i want to know the CDR module jitter tolerance value, or the requirement for the incoming serial data jitter.
2. For Transceiver IP, is there some parameters to configure for CDR pll bandwidth? or if FPGA datasheet or userguide to be refered in the intel webset?
- CheepinC_altera
Hi danduan,
As I understand it, you have some inquiries related to the CDR jitter tolerance in the AV devices. Please see my responses as following:
serial data jitter.
[CP] For your information, there is no generic jitter tolerance specs available in the datasheet. The AV CDR is characterized to be compliant to the jitter tolerance requirement of the supported protocols. Therefore, you can refer to the requirement in the supported protocol specs ie Ethernet. You can refer to the device handbook -> "Transceiver Protocol Configurations in Arria V
Devices" section on the supported protocols.
webset?
[CP] You can use the "CDR_BANDWIDTH_PRESET" QSF assignment to configure the bandwidth. You can refer to "Analog Settings Having Global or Computed Values for Arria V Devices" section in the XCVR PHY user guide.
Chee Pin
- danduan
Hi Chee Pin,
Thanks for your answer. I have another question.
1. I am trying to modify the parameter "CDR_bandwidth_preset", if i configure it to high, does it improve the CDR jitter tolerance? what is the difference between high and low ? For CDR pll, increasing CDR bandwidth, whether the pll will better trace the incoming data.
2. another parameter is PPM detector threshold, Its description is the maximum PPM difference the CDR can
tolerate between the input reference clock and the recovered clock. If I configure it to 1000, it means the recovered clock will be worse ???
- danduan
Hi Chee Pin,
- CheepinC_altera
Sorry for the delay. Please see my update to your latest inquiries:
[CP] For your information, the following are the discrepany between high vs low bandwidth setting. A high-bandwidth PLL/CDR provides a fast lock time and tracks jitter on the reference clock source, passing it through. A low-bandwidth PLL/CDR filters out reference clock jitter, but increases lock time.
Generally if you encounter jitter tolerance issue in your system, it is recommended for you to try with different bandwidth setting to see which one will helps.
2. another parameter is PPM detector threshold, Its description is the maximum PPM difference the CDR can tolerate between the input reference clock and the recovered clock. If I configure it to 1000, it means the recovered clock will be worse ???
[CP] For your information, value = 1000 meaning the maximum ppm difference between refclk and recovered clock that CDR can tolerate is +/-1000ppm. This is the maximum value that a CDR tolerate. It does not affect the recovered clock.
Chee Pin
- CheepinC_altera
Just would like to follow up with you on this. Thank you.
