ArriaV thansceiver jitter tolerance
Hi danduan,
As I understand it, you have some inquiries related to the CDR jitter tolerance in the AV devices. Please see my responses as following:
1. For Receiver PHY, PMA includes CDR module, i want to know the CDR
module jitter tolerance value, or the requirement for the incoming
serial data jitter.
[CP] For your information, there is no generic jitter tolerance specs available in the datasheet. The AV CDR is characterized to be compliant to the jitter tolerance requirement of the supported protocols. Therefore, you can refer to the requirement in the supported protocol specs ie Ethernet. You can refer to the device handbook -> "Transceiver Protocol Configurations in Arria V
Devices" section on the supported protocols.
2. For Transceiver IP, is there some parameters to configure for CDR pll
bandwidth? or if FPGA datasheet or userguide to be refered in the intel
webset?
[CP] You can use the "CDR_BANDWIDTH_PRESET" QSF assignment to configure the bandwidth. You can refer to "Analog Settings Having Global or Computed Values for Arria V Devices" section in the XCVR PHY user guide.
Chee Pin
- danduan6 years ago
Hi Chee Pin,
Thanks for your answer. I have another question.
1. I am trying to modify the parameter "CDR_bandwidth_preset", if i configure it to high, does it improve the CDR jitter tolerance? what is the difference between high and low ? For CDR pll, increasing CDR bandwidth, whether the pll will better trace the incoming data.
2. another parameter is PPM detector threshold, Its description is the maximum PPM difference the CDR can
tolerate between the input reference clock and the recovered clock. If I configure it to 1000, it means the recovered clock will be worse ???
Hi Chee Pin,
