9 years ago
Arria V PCIe hard IP
Hello everbody, I need help about PCIe configuration.
I work with arria V and i use PCIe hard IP.
My question is , we can have PCIe soft IP in Arria V ?
and my last question is we can drive in FPGA the input signal pin_perst of PCIe ?
thanks
    Because in the final card of my project i have affected the wrong signal for the reset pine and the final card is already been manufactured.
    So i have to move the reset pine in the arria 5 but it is impossible because this pin is dedicated pine.
    I thought if i use SOFT core i can chose the all pine who will use the PCIe.
    sorry my english is not very good , i don't know if you understand.
    thanks for your time.
    For Arria V device, the mapping of nPERST is as below:
    - nPERSTL0 --> bottom Hard IP of pin_perst
    - nPERSTL1 --> top Hard IP of pin_perst
    In your case, try workaround it by changing to use Soft Reset Controller.
    Using Soft Reset Controller doesn't required the connection to pin nPERSTL0. Tie pin_perst to 1 at top level file and nPERSTL0 can be left unconnected at pin assignment.
    Steps to switch to soft reset controller in Qsys:
    1) Edit the .qsys file
    2) Search for the string 'force_src'
    3) Set parameter force_src to 1:
    <parameter name="force_hrc" value=0" />
    <parameter name="force_src" value=1" />
    4) Save the changes to the .qsys file and regenerate the Qsys system.
    5) Use npor input to reset the core and application logic.
