9 years agoArria V PCIe hard IP
Hello everbody, I need help about PCIe configuration. I work with arria V and i use PCIe hard IP. My question is , we can have PCIe soft IP in Arria V ? and my last question is we can drive...
8 years agoFor Arria V device, the mapping of nPERST is as below:
- nPERSTL0 --> bottom Hard IP of pin_perst - nPERSTL1 --> top Hard IP of pin_perst In your case, try workaround it by changing to use Soft Reset Controller. Using Soft Reset Controller doesn't required the connection to pin nPERSTL0. Tie pin_perst to 1 at top level file and nPERSTL0 can be left unconnected at pin assignment. Steps to switch to soft reset controller in Qsys: 1) Edit the .qsys file 2) Search for the string 'force_src' 3) Set parameter force_src to 1: <parameter name="force_hrc" value=0" /> <parameter name="force_src" value=1" /> 4) Save the changes to the .qsys file and regenerate the Qsys system. 5) Use npor input to reset the core and application logic.
