Mircea's avatar
Mircea
5 years ago
Arria V - LVDS output performance
My 5AGXFB7H4F35C4 receives a 125MHz, ideal reference clock.
Using the internal PLL, I want to generate a 500MHz sampling clock for controlling 8 ADC chips.
1. What is the maximum clock frequency coming out of this device in LVDS?
2. What would be the jitter?
3. What setting should I use, and what output pin for best performance?
I also want to send a 2ns wide SYNC pulse on 8 outputs.
4. What would be the skew between the 8 outputs?
5. What is the minimum pulse width for LVDS outputs?
6. What setting should I use, and what pins for best performance?
7. Where can I read these specs?
Please, don't tell me to just read some 10,000-page data sheet.
Mircea
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi Mircea
    Can you check if Table 40 of below doc is what you are looking for?
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_51002.pdf
    For output pins, depends on clock or IO types, you can refer to below link:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/arria-v/pcg-01013.pdf
    And map your device to the pin out file:
    https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
    For skew handling, you can refer to timing constraint chapter 1.5.4 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altlvds.pdf
    Eng Wei
    • Mircea's avatar
      Mircea
      Hi Eng Wei,
      You only answered question 7.
      If you don't know the answers for questions 1 to 6, please ask someone who knows, and get back to me.
      Here are my questions again:
      1. What is the maximum clock frequency coming out of this device in LVDS? It's not through the ALTLVDS.
      3. What setting should I use, and what output pin for best performance? Please, give example of pin number and setting.
      6. What setting should I use, and what pins for best performance? Please, give example of pin number and setting.
      Mircea
        EngWei_O_Intel
        Hi Mircea
        If you aren't using LVDS SERDES IP, then you shall refer to PLL spec (Table 36) in the same document.
        For differential signal input/output pins, you should always pick from DIFFIO_RX* or DIFFIO_TX* from the list, depends on which IO banks you are using. The min pulse width depends on the max freq achievable in your design.
        For clock skew specific question, I would suggest you to file another request and timing expert will be able to assist you.
        Eng Wei
