13 years agoArria ii Gx Remote Update Giving Pof Error once it get error
Hi, I using arria ii gx fpga with epcs128 flash attached. I Using altera remote update and parallel mega functions for upgrade epcs over processor. i have divided flash into 3 pages. page0 has ...
13 years agoHi All,
After many trial we found the solution. it just maters what frequency you running parallel function. we observed there is signal integrity issue on the board. which causing the crc to fail at the boot up and showing the pof error. so we have reduce the frequency in khz and sorted out the issue. Now its working with the two pages+ 3 pages even smoothly with all the test cases we planned. Thanks, Shivaji M
