16 years agoArria II GX refclk pins
Hi there, Is there any assignment I need to set when I use the refclk pins as clk inputs? I am using EP2AGX65CU17C6 device. We connected a differential clock input to pin M19 and M20, which is ...
16 years agoI removed the the signal from my top level since I am not using it anywhere in the design, then the problem went away. This leads me to think that, if I am driving the ref_clk of the altgxb ip from an internal PLL, I shouldn't be assigning any signal to the dedicated ref_clk pin.
Thank you all for your replies!
