16 years agoArria II GX refclk pins
Hi there, Is there any assignment I need to set when I use the refclk pins as clk inputs? I am using EP2AGX65CU17C6 device. We connected a differential clock input to pin M19 and M20, which is ...
16 years agoHua,
This pin clock is for transceivers. It can't be used with other logic. I'm using EP2AGX65CU17C6N too. I use this pin clock with a PCI Express core (Reference clock from motherboard). The block of assignment in Quartus Setting File of my project: set_instance_assignment -name IO_STANDARD HCSL -to pcie_refclk set_instance_assignment -name INPUT_TERMINATION OFF -to pcie_refclk set_location_assignment PIN_M19 -to pcie_refclk
