16 years agoArria II GX refclk pins
Hi there, Is there any assignment I need to set when I use the refclk pins as clk inputs? I am using EP2AGX65CU17C6 device. We connected a differential clock input to pin M19 and M20, which is ...
16 years agoI did set the I/O signal as lvds in pin planner. Is that enough? Are you saying I should set pins M19 and M20 as lvds in the assignment editor?
