15 years agoArria 2 DDR3 shared PLL
Hi, I have two DDR3 instantiations in my design. I'm low on PLL resources and I need to share the PLL of the two DDR3 inst. In the documentation I saw that the ALTMEMPHY does not support u...
15 years agoIs it the PLL you're low on or clock outputs? I'm pretty sure a number of the clocks can be shared via assignments. The altmemphy handbook talks about it. But you're right that altmemphy requires two different PLLs for some of the clcoks.
