Arria 10 Transceiver PHY parameters for CDR
Dear TerryU,
Thanks for your update. Regarding the refclk input specs, you may refer to the device datasheet -> "Reference Clock Specifications" section for further details on the requirement.
Regarding the intermittent range of the cdr_pll_set_cdr_vco_speed, sorry as I do not have insight on it because there is no detail on this internal parameter in the existing documentation nor database that I can access. Sorry for the inconvenience.
By the way, if you would like to proceed using the workaround of customizing this parameter, it is recommended for you to perform thorough verification to ensure your system are working per your expectation.
Chee Pin
- TerryU7 years ago
Hi Chee-san,
I have replaced oscillator with fast edge one, rising/falling 200ps (typ), and checked performance. However result was almost same with before. So some FPGA internal analog process or QUARTUS setup might be root cause. Anyway I set optimal value for our boards, and will do qualification test. Indeed, there is a risk without technical background though.
TerryU
