Arria 10 IOPLL not locking when reconfiguring
- 5 years ago
Hi @Ash_R_Intel ,
I just found, that I made an programming error and didn't configure the Loop Filter correctly. PLL is now locking. Many thanks for your patience and help.
Hi @Ash_R_Intel ,
I am following AN 728 and applying the avalon reset of the IOPLL after reconfiguration (asserting for 1 ms and waiting for 1 ms until evaluating lock).
Also I write 0 to address 0 after each command now.
Lock goes high for 722 clock cycles (measured with signaltap, 100 MHz -> 7.22 us) before going low again.
Timing is met for 240 MHz output clock and for 240 MHz the PLL locks without trouble (without reconfiguration). After reconfiguration with the same values that the PLL is initially configured with results in a loss of lock. The PLL is configured in direct mode. Changing this to normal or source-snychronous didn't change the behaviour either.
Many thanks for your help
Hi @Ash_R_Intel ,
