Arria 10 "HPS GMII to SGMII PCS Bridge IP" ports differ from "SGMII PCS IP"
Some context:
I am designing for an Arria 10 SX FPGA, Quartus Prime Pro Edition, and I need an SGMII interface
The embedded peripherals user guide mentions connecting the HPS GMII to TSE 1000BASE-X/SGMII PCS Bridge IP and the Triple-Speed Ethernet intel FPGA IP as a method for the HPS to use SGMII.
The latter can be configured to operate in 1000BASE-X SGMII PCS ONLY mode, where the bridge comes in to connect it to the HPS GMII interface.
The bridge IP has a clock enable interface that it is to receive from the 1000BASE-X SGMII PCS IP. The documentation of the 1000BASE-X SGMII PCS IP also mentions the clock enable signal in section 6.1.12.3. However the clock enable port is missing from the 1000BASE-X SGMII PCS IP.
The parameter for enabling the clock enable signal within the IP is greyed out as its applicable only when the Triple-Speed Ethernet IP is used as a MAC.
Platform Designer also throws out a warning that the clock enable signal of the bridge IP must be connected to something
My question(s)
Since the clock enable is an input of the bridge, can I just connect it to/set it logic high? Or will it not work since the bridge IP expects it to be driven by the PCS IP?
Any other work-arounds?
Thanks for the help
- Jeet14
We have an Knowledge Data Base-KDB on this and refer the design mentioned on the below link-
https://www.intel.com/content/www/us/en/support/programmable/articles/000092330.html
Tiwari
- Jeet14
Let me know if you have any query on this.
Tiwari
- Jeet14
