R_G
2 years agoArria 10 Custom Board EMIF Settings
Hi, I am having trouble with memory verification checks (write of a pattern followed by a readback) that are failing for the external DDR4 memory of our Arria 10 custom designed board. This is preve...
AdzimZM_Altera
2 years agoHi Richard,
Thank you for your feedback.
I have looked into the u-boot_log_tRFC350_CL26_CW16_tRC43_1_24MHz.txt and found that the ddr size check is now passing.
I don't think you have stated the "The verify error - read following write of a known value - is still there in the debugger log" before.
This issue might be specific to u-boot area.
So I encourage you to open a new forum for this issue on u-boot debug section.
Adzim
