15 years agoAria II GX ALTGX Serdes issue-Serdes Expert needed
Maybe there is someone out there who can help with this... We are using an Aria II GX device. We have a 150 MHz diff clock coming into a refclock location. I/O standard is the 1.5V PCML. Thi...
15 years ago --- Quote Start --- The board is already laid out --- Quote End --- Then I don't excatly understand the above description. --- Quote Start --- We have a 150 MHz diff clock coming into a refclock location. --- Quote End --- --- Quote Start --- Take the clock directly into a PLL rather than the xcvr --- Quote End --- Where did you actually connect the clock with the present board? According to the device manual, "Scenario 1" should be supported by the Arria II hardware. Unlike with Arria (I), refclk can be also supplied from dedicated PLLs.
