13 years agoanyway to improve the reliability of triple SDI rx IP
Hi My design has a triple SDI transceiver and several video processing IPs. A basic test for this design is to use video standards of SDI (487i, 576i, 720p, 1080i, and 1080p) as input and to ...
13 years agoErrr....based on my experience with the core and the inner working, I feel that it is not the core that is affecting you. It is possible that your external stuff like jitter, power supply and noise that is affecting your stability.
One way to verify is to just run at HD-SDI, with 74.25MHz clock, and try various format. If you are still having problem, then it is definitely your external stuff.
