15 years agoany way to disable the packet support of SGDMA in 10.1
Is there any way to turn off packet support of SGDMA for stream-to-memory in v10.1? It seems not option to disable the packet support. I got follow message: Error: ADC/sgdam_0.in: the sink ...
15 years agoLike others have said those signals are always enabled and adapters will be needed to bridge the gap. If you are not already far into your design you may want to take a look at my mSGDMA which you can turn off those signals: http://www.alterawiki.com/wiki/modular_sgdma It has a different program model (it's much easier to handle in software) but it doesn't support descriptor pre-fetching .... yet.
