13 years agoaltserial_flash_loader shared access
I've been trying to get both the JTAG indirect flash programming and a user design utilizing the SPI interface to work. Both cores work independently. I am feeding dclk_in with a 20MHz output of an a...
13 years agoNevermind! I've discovered the undocumented interface behind the altserial_flash_loader:
component stratixiv_asmiblock port( dclkin : in std_logic; scein : in std_logic; sdoin : in std_logic; data0out : out std_logic; oe : in std_logic); end component; I removed the bad clock multiplexing code in altserial_flash_loader and wrote my own. Now everything works perfectly.
