16 years agoALTPLL 600MHz output
Hi, I need to get clarification on the ALTPLL in the Megawizard. I'm using a DE3 board and I want to run my verilog-code in 600MHz (just some simple registers for now), this should be po...
16 years ago --- Quote Start --- I feared something like this. A standard oscilloscope probe makes the signal quality considerably worse, also the GPIO connector PCB wiring isn't intended for high speed. You can route the PRBS signal to the clk_out connector to get an idea of the real waveform. Your oscilloscope would still not show a square wave due to bandwidth limitation, but it should look more regulare. --- Quote End --- Good idea, will try that, thanx!
