16 years agoALTPLL 600MHz output
Hi, I need to get clarification on the ALTPLL in the Megawizard. I'm using a DE3 board and I want to run my verilog-code in 600MHz (just some simple registers for now), this should be po...
16 years ago --- Quote Start --- seems like i need a much faster oscilloscope then --- Quote End --- Yes, as said. I also wonder, at which DE-3 connector you accessed the PRBS output?
