11 years agoAltmult_add and Almult_accum dsp ip cores blocks
Hello. Using Quartus II 10.1 with Stratix IV GX. I'm trying to use and make with the Megawizard, DSP block that can be an adder, subtractor, multiplier for two inputs of 18bit, and also I...
11 years ago --- Quote Start --- you are right. 4 mults + adder needs half dsp block. So I only have to guess it could be your mode is not just that of 4 mult/add as you have accumulator. I am not sure about these blocks configurations exactly. --- Quote End --- Thank you. I'll try to find out the reason.. Lior.
