11 years agoAltmult_add and Almult_accum dsp ip cores blocks
Hello. Using Quartus II 10.1 with Stratix IV GX. I'm trying to use and make with the Megawizard, DSP block that can be an adder, subtractor, multiplier for two inputs of 18bit, and also I...
11 years agoStx IV half dsp block supports 18x18 but you have 4 inputs so you need two of these halves (which is why you got 2 of dsp 18x18)
