11 years agoAltmult_add and Almult_accum dsp ip cores blocks
Hello. Using Quartus II 10.1 with Stratix IV GX. I'm trying to use and make with the Megawizard, DSP block that can be an adder, subtractor, multiplier for two inputs of 18bit, and also I...
11 years ago --- Quote Start --- For the given functionality, switch it from being "Enabled" to "Variable" and the input ports will be created. e.g. for ALTMULT_ACCUM Saturation, go to the Saturation tab in the wizard, change "Should saturation operation be performed at the output adder(s)?" from "Enabled" to "Variable". Then click the "More options.." button right below that to possibly configure additional settings for that port. --- Quote End --- Thank you so much. It was helpful!
