15 years agoAltmemphy Version 9.0SP2 --> 10.0SP1
Hi, i have a problem by generating a new altmemphy with Quartus 10.0SP1. The compile works with Q9.0SP2 but a new generation with Wizard 10.0SP1 make problems. This ist the error: Er...
15 years agoHi Sanjay,
if you remove the "derive_pll_clocks", you have to set all pll_clocks by yourself. Otherwise timequest have unconstraint clocks and can't analyze these clocks. If there are problems with "derive_pll_clocks", maybe it's another problem? Regards, Josef
