15 years agoAltmemphy Version 9.0SP2 --> 10.0SP1
Hi, i have a problem by generating a new altmemphy with Quartus 10.0SP1. The compile works with Q9.0SP2 but a new generation with Wizard 10.0SP1 make problems. This ist the error: Er...
15 years agoI created a brand new variation in 10 sp1 and still get this error. I followed the instructions provided by the megawizard to the letter... except to set the top-level entity in the project to ddr3_ip_example_top. Why would I want to do that if I am instantiating the design in my top-level?
From the DDR Megawizard generator Info: Generating the Example Design. Info: Generating the Pin Planner file. Info: Generating the Synopsys Design Constraints file for the example top level. Info: Generating the Synopsys Design Constraints file. Info: Generating the Timing Report script. Info: Generating the ALTPLL Megafunction instance. Info: Generating the ALTMEMPHY Megafunction instance. Info: Generating the Functional Simulation Model for ALTMEMPHY Info: Before compiling your variation in Quartus II, you should follow these steps: Info: - Enable TimeQuest under Settings, Timing Analysis Settings. Info: - Add the ddr3_ip_phy_ddr_timing.sdc file to your Quartus II project. Info: - Add I/O Standard assignments by running the ddr3_ip_pin_assignments.tcl script. Info: - Set the Default I/O standard to match the memory interface I/O standard setting. Info: - Turn on Optimize multi-corner timing in the Quartus II Fitter Settings. Info: - Please make sure that address/command pins are placed on the same edge as the CK/CK# pins. Info: - Set the top level entity of the project to ddr3_ip_example_top. Info: See the User Guide for more details.
