14 years agoALTLVDS_RX megafunction
Hi, guys: when i build a new project with HDL and megafunction , I use the ALTLVDS_RX for adc data(8 channels and deserialization factor is 1) and it works . Now, I want to generate a system i...
14 years ago --- Quote Start --- And what are Avalon-ST 'source' and 'sink' ? --- Quote End --- Altera's definition of a streaming bus. Read the Avalon Interface Specification. http://www.altera.com/literature/manual/mnl_avalon_spec.pdf --- Quote Start --- How about SG-DMA ? --- Quote End --- You still need to make the ADC look like an Avalon-ST component, so that you can connect it to a DMA controller. --- Quote Start --- On my board, a ddr2 is used for Nios ii CPU ,and I allocate some space for adc data . So I want to stream the adc data into ddr2 sdram and then stream out via uart port. Which Avalon-ST components are all right ? --- Quote End --- There are DMA controllers that can transfer data between an Avalon-ST component and bus master an Avalon-MM bus to access a DDR controller. I've never used any of them. I just write my own when I need them. Cheers, Dave
