13 years agoALTLVDS_RX doesn't compile
I'm trying to implement the ALTLVDS_RX IP using an external PLL and I get the following error if I enable the option "Use 'rx_data_reset' input port": Error (287102): Input pin "rx_data_reset" cannot be assigned a value Error (287103): Input port "auto_generated.rx_data_reset" cannot be used as a value Error (287103): Input port "auto_generated.rx_data_reset" cannot be used as a value The following assignment in line 741 of the file altlvds_rx.tdf seem to be wrong: IF USED(rx_data_reset) GENERATE rx_data_reset = auto_generated.rx_data_reset; END GENERATE; Quartus Version: 11.1 Service Pack 2.11 FPGA: Cyclone IV GX RalfNo RepliesBe the first to reply
