16 years agoALTLVDS pins io standard
hi, I am using ALTLVDS megacore for serialization and deserialization. the serializer has tx_out : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) and the deserializer has rx_in : IN STD_LOGIC_VECTOR ...
16 years agoquartus 9.1sp1 fitter error
Error: Found two LVDS low registers instead of one! Error: Found two LVDS high registers instead of one! for this piece of code generated by megawizad // synopsys translate_off initial dataout_h_reg = 0; // synopsys translate_on always @ ( posedge clock) dataout_h_reg <= ddio_h_reg; // synopsys translate_off initial dataout_l_latch = 0; // synopsys translate_on always @ ( negedge clock) dataout_l_latch <= ddio_l_reg; // synopsys translate_off initial dataout_l_reg = 0; // synopsys translate_on always @ ( posedge clock) dataout_l_reg <= dataout_l_latch; // synopsys translate_off initial ddio_h_reg = 0; // synopsys translate_on always @ ( posedge clock) ddio_h_reg <= datain; // synopsys translate_off initial ddio_l_reg = 0; // synopsys translate_on always @ ( negedge clock) ddio_l_reg <= datain; assign dataout_h = dataout_l_reg, dataout_l = dataout_h_reg; endmodule //RxLVDS_lvds_ddio_in
