11 years agoALTFP_MULT always return 0
Hi everyone, I'm new to fpga/verilog and met a weird problem when using altfp_mult ip core. --------------------------------- I am using de2i-150 developing board, which has an Intel Atom CPU...
11 years agoYour problem sounds like you are not correctly storing 'dataa' and 'datab' in registers after you write them from PCIe.
If you look closely (SignalTap) I think you will find that the result isn't always 0, but it is only zero when one or more of the inputs are also zero.
