15 years agoALTFP_MATRIX_MULT problem in Quartus 10.0
I generated a ALTFP_MATRIX_MULT in Quartus 10.0, but there are many error when I start compilation. How can I fix it? Thanks, Xiyi Error: Node instance "cmp0" instantiates undefined enti...
15 years agoI was going to go try to generate a new ALTFP_MATRIX_MULT design in Quartus 10 but it seems to greyed out now that I've update to SP1 so I can't select it for generation. Perhaps Altera has found that it is buggy and has disabled it until they fix it.
You could try downloading Quartus 9 and generating a new ALTFP_MATRIX_MULT design using that, it should hopefully be a bit more stable. You should still be able to compile it in Quartus 10 if you need to.
