15 years agoALTFP_MATRIX_MULT problem in Quartus 10.0
I generated a ALTFP_MATRIX_MULT in Quartus 10.0, but there are many error when I start compilation. How can I fix it? Thanks, Xiyi Error: Node instance "cmp0" instantiates undefined enti...
15 years agoYou can try editing you .qsf to make the altfp_lib.vh map to a library.
In your project project directory there should be a .qsf file that has a line that looks like thisset_global_assignment -name VHDL_FILE "altfp_lib.v" Modify this line to set the library name: set_global_assignment -name VHDL_FILE "altfp_lib.v" -library altfp_lib I'm not sure if this is the problem, but it might help. I'm just guess here. If your design works fine with just commenting out that line then no need to do this. I should note that there's probably a way to set the library for a file in Quartus, but I'm not sure how it would be done because I always use the qsf to modify project settings.
