15 years agoALTFP_MATRIX_MULT problem in Quartus 10.0
I generated a ALTFP_MATRIX_MULT in Quartus 10.0, but there are many error when I start compilation. How can I fix it? Thanks, Xiyi Error: Node instance "cmp0" instantiates undefined enti...
15 years agoThere is the altfpc_lib.v in the output directory, but the altfpc_lib isn't included in my project, so I inclede it manually. And the error is:
Error: Node instance "sd3" instantiates undefined entity "altfpc_lib". The .qip reads as follows, is that right? set_global_assignment -name IP_TOOL_NAME "ALTFP_MATRIX_MULT" set_global_assignment -name IP_TOOL_VERSION "10.0" set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0.v"] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0.bsf"] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0_inst.v"] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0_bb.v"] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0.inc"] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) "altfp_matrix_mult0.cmp"] When I commented the code "//altfpc_lib sd3( )", there's no error. Then I will test the function of altfp_matrix_mult.
