15 years agoALTFP_MATRIX_MULT problem in Quartus 10.0
I generated a ALTFP_MATRIX_MULT in Quartus 10.0, but there are many error when I start compilation. How can I fix it? Thanks, Xiyi Error: Node instance "cmp0" instantiates undefined enti...
15 years agoThe altfpc_lib should have been generated by the megawizard alongside the altfp_matrix_mult file. If you don't see it try re-generating the altfp_matrix_mult (open megawizard, select edit an exisitng, find your existing altfp_matrix_mult file, keep clicking next until its finished, click ok to replace the files). Then have a look in the output directory and see if it created the altfpc_lib. If it is make sure it's included in your project (probably already included in the .qip). Now try compiling again.
