JHill1
5 years agoALtera/Intel CIC IP non-determanistic result when selecting Hogenauer pruning
I don't know where one might submit a bug report for the Intel FPGA IP so I submit one here.
When I configure the Intel/Altera CIC Digital Filter IP for Hogenauer pruning I noticed that the s...
CheepinC_altera
5 years agoHi,
Sorry for the delay. This case was just routed to me. As I read through the discussion, seems like you have managed to resolve the initial problem.
Just would like to check with you if there is any other specific problem that I can further assist.
- JHill15 years ago
Maybe the CIC IP remains defective when it doesn't automatically choose sufficient number of internal accumulator bits so that an anomalous output is _not_ produced with hogenauer pruning option and for the single most negative two's complement input value, as detected when performing a DC linearity test.Perhaps the customer shouldn't need to add an additional (duplicated) sign bit to the CIC input to fix Altera/Intel CIC internal implementation issues?Alternatively, if avoiding such problems by adding an additional (duplicated) input sign bit, is seen as a user implementation choice, resource consumption trade-off, by Altera/Intel then at a minimum perhaps the single anomalous output situation should be documented in the Altera/Inte CIC manual suggesting also the possibility of adding an additional (duplicated) sign bit to the input as a workaround, from my humble perspective.Thanks for your interest and best regards,JHill1
