15 years agoAltera transceiver bits swapped
Hi all. I'm working on a simple transceiver loopback test using a stratixIV GX development kit. I instantiated a simple ALTGX function in basic (PMA direct) mode, and i attached the altera lo...
15 years agoThanks a lot dwesterg,
So for a "raw" transmission i need to implement myself a synch word and a FSM to realign the received data, right? But if i use a protocol (eg basic x4) i see in the signaltap anlyzer that the bits keep swapping. let's say the synch word is "0101111100", is it sent automatically or do i need to inject it periodically in the data? Thanks again! Marco (EDIT) the answer was yes, i need to inject the synch word and use an optional port to tell the transceiver when to realign. tnx
